Community Member
PDM for PIX506 question
Dear Everybody,
I'm not sure what i did wrong over the setup, but I was trying to access the PIX using the PDM, somehow i'm keep getting the error message after i type in the password,
"Yor PIX image has a version of unknown. This version of PDM
will only interoperate with versions taht start with 6.0 or 6.1. Please update your PIX image so that they are compatible"
and here is the show ver of my PIX506
SUN-PIX# show ver
Cisco Secure PIX Firewall Version 6.0(1)
PIX Device Manager Version 1.1(2)
Compiled on Thu 17-May-01 20:05 by morlee
SUN-PIX up 18 mins 37 secs
Hardware: PIX-506, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 8MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0006.532f.28a6, irq 11
1: ethernet1: address is 0006.532f.28a7, irq 10
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES: Enabled
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
Websense: Enabled
Throughput: Limited
ISAKMP peers: Unlimited
Serial Number: 405270601 (0x1827f049)
Activation Key: 0x9f04f704 0x92d9939d 0x016ba94b 0xb1e2ea78
SUN-PIX#
I have a PIX501 with me, it's working perfectly fine with PDM on that one, just can't access to the 506 through the PDM. any suggestion would be really appreicate
thanks
Community Member
Re: PDM for PIX506 question
Hi everyone,
Just want to add something, i event try a brand new PIX506E, it's comes with PIX Version 6.1(4) and PDM 1.1(2), but i'm still getting the same error message when i try to access it through PDM, why?
any suggestion would be really apprecaite thanks
Simon
Community Member
You may update your PDM version to 2.11 to resovle these issues. I know the new version makes it a lot cleaner to work with.
90
