PDM is not accessible
I can telnet the PIX (501), PDM version 3.0(1) is installed, http server is enabled, PDM is configured and the host is allowed, still I can't access the PDM. Web browser displays the message "the page can not be displayed"?
any help will be appreciated.
Gold
Re: PDM is not accessible
are you using https when you type in the url? also, what version of java have you installed? I found that java 2 runtime environment se v1.4.2 and later may not work with pdm.
if it doesn't resolve the issue, please post your config.
yes, I type https. Ican access one other PIX in our network. only difference is that we have a concentrator in between lan and PIX (which PDM is not accessible). I can telnet to it but the only problem is with PDM. what about 3020 concentrator, would it make any difference?
config:-
pdm location 62.130.x.0 255.255.254.0 inside
pdm history enable
http server enable
http 62.130.x.0 255.255.254.0 inside
try using java 1.4.2 or upgrade the pdm
see this link
http://forum.java.sun.com/thread.jspa?threadID=610328&start=15
Gold
just wondering how you go.
117
