PDM location statements
I have setup PDM on my PIX 515. After setting it up it added a PDM location statement for every network in my access lists. I try and remove the unwanted PDM locations but they just get added back in.
Below is how I configured PDM on the PIX. What have I done wrong?
pdm history enable
http server enable
http 10.107.128.0 255.255.255.0 inside
plus about 50 PDM location statements.
Scott
Re: PDM location statements
You do not need to be concerned about the PDM location commands. They are auto-generated by PDM and are used by PDM to represent network objects. You can delete them all and the next time PDM starts, it will auto-generate all that it needs. I could have sworn there was an FAQ on this but I cannot find it now. If anyone else has this info, please fell free to attach it to this thread. Hope this helps.
Scott
Gold
Scott,
Here is the explanation:
A PDM location is a pure book keeping command used by PDM to build its topology
database.
It has nothing to do with the PIX's functionalities. In particular, it
does
**NOT** control which host can access PDM which is a common
misunderstanding.
The control is done by the command "http ".
Why do we need it?
In PDM's world, policy (those rules) is built on top of topology.
Ideally user creates the topology first via the Host/Network tab, then
configures policy else where (like Access Rule tab). A network object
exists by itself, even if there is no policy configured directly on it
at a particular time. We use "pdm location" command to remember the
location
of a network object.
Hope this explains it for you.
Jay.
165
