Community Member
PDM Problems
I have recently installed Pix 6.3.1 and PDM 3.0.1 for a customer. Personally, I never use PDM but my customer is keen to because he doesn't know the command line too well and there are lots of object-group and long ACLs to administer. The first query I had was an initial screen where the PDM's not sure
which interface specific names/ip addresses reside on. From an earlier posting, I believe that PDM requires a PDM location for everything and by confirming the interface, a pdm location will be built. Is this correct? Is it possible/recommended to add pdm locations manually at the CLI?
My next query is with names and object-groups. Some appeared to be missing but when I try to enter them, pdm complains that they already existed? This is no good if we want to create an additional ACL entry using the name/group.
Lastly, I have lots of null entries in my ACLs. I am not sure if this is a result of "missing" names and object-groups? Are these entries ignored when premitting/denying traffic? Also, when I expand ACL entries, some of the addresses/names/object-groups appeared to be on the wrong interface. I tried correcting the interface but then there was no groups available to select in the drop down boxes.
To summarise, I think these problems stem from names/groups not being assigned to correct interfaces. I am looking for some guidance on how to tidy this up so that pdm can be used to manage ACLs.
Many thanks in advance,
Tracey
Silver
Re: PDM Problems
Some object-group commands are not fully supported by the PDM and this might be the cause of your problem. Please see the following URL for more information: http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pdm/v_30/pdmrn30.htm#68551.
Community Member
Re: PDM Problems
Thanks for your reply. I will look into this. We are definitely using "object-group protocol" which is not supported.
Tracey
Community Member
Re: PDM Problems
With regards to setting PDM location, I find that the easiest option is to use the setup command from the cli prompt + enter the pdm location there.
PIX(config)#setup
IP address of host running PIX Device Manager: 192.168.254.1 255.255.255.0
This automatically creates all the entries required to run the PDM from the specified host + can be run at any time.
92
