PDM Question
Is there a possibility to display the active connection state in the PDM ?
normaly i use the command " sho connenction "
Thank you
Re: PDM Question
Hi ,
You can use the command " show pdm sessions" as well.
It will give you the information you want.
Hope this helps.
Thank you
Tony
Re: PDM Question
Hi Tony ,
Thank you for your answer. I want test asap .
regards
hermann
86
