12-14-2002 11:04 AM - edited 02-20-2020 10:26 PM
I just upgraded our PIX 515 from 6.1 to 6.2. I also added DES support and loaded PDM ver. 2.1. I am trying to browse to the PDM, but I cannot. What am I missing?
Solved! Go to Solution.
12-15-2002 04:44 AM
did you add the following lines to your config and did you use HTTPS to browse to the pix (http is not supported, only https)?
http server enable
http A.B.C.D 255.255.255.255 inside
A.B.C.D is the ip address of the host from which you are trying to reach the pix with the pdm.
If you're still having problems after adding these two lines, you could have a look at this page:
http://www.cisco.com/warp/customer/110/pdm_http404.shtml
Kind Regards,
Tom
12-15-2002 04:44 AM
http server enable
Kind Regards,
Tom
12-15-2002 04:24 PM
I did the https, but I did not enter the http server enable command. I'll try it on Monday, thanks for your help.
Gary
