Community Member
Permit port 8080 only for specific site
Hallo
Ok I'll straight forward to the problem,
Lets say I just want permit port 8080 only for specific site and deny port 8080 for all sites that using it, can I do that on my PIX 506 (version 6.2)
Community Member
Re: Permit port 8080 only for specific site
Just to clarify,
You'd like to allow your internal users to access an external site via port 8080?
And by site are do you want to identify it by the IP address, or by the URL?
Cheers,
Tim.
Community Member
Thanks Tim
http://abc.testing.com:8080/trak/testing.asp.
I already setting my pix with this command
access-list 190 permit tcp host xxx.xxx.xxx.xxx any eq 8080
With that command I belief all my internal users can access using port 8080.
What I want is, only that site (using port 8080) can be access by my internal users.
Thanks alot
Thomas
Community Member
I think what you want to do is switch it round.
ie.
access-list 190 permit tcp [internal IP range] host xxx.xxx.xxx.xxx eq 8080
Then apply the list on the internal interface in an inbound direction.
Cheers,
Tim.
105
