PFS on PIX---Cisco VPN client connection
Does any body try to enable PFS on PIX to Cisco VPN connection. I'm not sure did i do it right or not, but everytime when i enable the PFS function on the PIX, and I try to create a connection from the client, i always get stuck at the last stage, which is saying "Securing Communication Channel".
here is my code on the PIX506
crypto dynamic-map dynmap 50 set transform-set SyscomNYSet
crypto dynamic-map dynmap 50 set pfs group2
are there anything else i need beside the second line?
any suggestion or tip would be appreciate.
Actually i try this on IOS(router) with VPN client connected to it, it works fine.
thank you
Silvia
1 REPLY
Re: PFS on PIX---Cisco VPN client connection
There is another command in the PIX you need add in to make it working.
"vpngroup pfs"
I just tried it on my PIX with 6.2.1 code, it did work.
Best Regards,
Paul Qiu
397
