ping and other config issues perim int tomdmz e3 to inside e1
PLEASE SEE CONFIG
I wanted to write net a config from a pc on inside to a pc on the tomdmz and vice versa. Sho log reports " No Route to 192.168.2.2 from 192.168.1.1"
I believe my ACLs and Group are correct. I also believe my Static statement from inside to tomdmz is correct. Why is my inside not able to see and pass traffic to my tomdmz int. I am ne w to pix and appreciate any assistance.
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 tomdmz security90
nameif ethernet3 kawdmz security80
nameif ethernet4 intf4 security20
nameif ethernet5 intf5 security25
enable password xxxxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxxx encrypted
hostname xxxxxxxxxxx
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list acl_tomdmz permit ip any any
access-list acl_tomdmz permit icmp any any
pager lines 24
logging on
logging timestamp
logging buffered debugging
interface ethernet0 10full
interface ethernet1 100full
interface ethernet2 10full
interface ethernet3 100full
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
mtu outside 1500
mtu inside 1500
mtu tomdmz 1500
mtu kawdmz 1500
mtu intf4 1500
mtu intf5 1500
ip address outside pppoe setroute
ip address inside 192.168.1.1 255.255.255.0
ip address tomdmz 192.168.2.1 255.255.255.0
ip address kawdmz 192.168.3.1 255.255.255.0
ip address intf4 127.0.0.1 255.255.255.255
ip address intf5 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address tomdmz 0.0.0.0
failover ip address kawdmz 0.0.0.0
failover ip address intf4 0.0.0.0
failover ip address intf5 0.0.0.0
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.1.0 255.255.255.0 0 0
nat (tomdmz) 1 192.168.2.0 255.255.255.0 0 0
nat (kawdmz) 1 192.168.3.0 255.255.255.0 0 0
static (inside,tomdmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0 0 0
access-group acl_tomdmz in interface tomdmz
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
vpdn group pppoe-sbc request dialout pppoe
vpdn group pppoe-sbc localname xxxxxx
vpdn group pppoe-sbc ppp authentication pap
vpdn username xxxxxx password xxxxxxxxx
dhcpd address 192.168.1.20-192.168.1.30 inside
dhcpd dns 151.164.11.201 151.164.20.201
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
Cryptochecksum: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
1 REPLY
Re: ping and other config issues perim int tomdmz e3 to inside e
Here is what you can do :
Remove Static
Add the following Statements
access-list XYZ permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list XYZ permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
nat (inside) 0 access-list XYZ
nat (tomdmz) 0 access-list XYZ
I hope this works. Good Luck!
Desh
94
