ping guestion and clock question
I have two question,please help me!
1. I want to ping host from inside to outside,but not outside to inside or to dmz,I can use ACL in my router to do it,but i don't know how to do in my pix525.
2.I use "sh clock" to find my pix system time is correct,but when i use browser to monitor my pix status,the time is incorrect!(pix device manager interface)
example : I watch cpu utilization graph,the graph real time is error?why?
Re: ping guestion and clock question
Cisco recommends only to open ICMP access on the interfaces you want to test. Therefore, disable pinging so that the PIX Firewall unit is not visible on the network. Having open ICMP access increases PIX Firewall operation overhead and can let attackers probe your network. Check out this link:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_60/config/config.htm#29662
If you allow ICMP echo-reply only, then that should allow you to ping out, but not users to ping in an incoming fashion.
The only way to allow a inside host to ping a outside host and get a reply is to allow echo-reply at the outside interface of your pix. This will also allow host on the outside to ping your pix's outside interface, but they cannot ping your dmz or inside host without you giving them access with a ACL.
Here is an example of a ACL that I am using:
access-list acl_outside permit icmp any any echo-reply
access-list acl_outside permit icmp any any source-quench
access-list acl_outside permit icmp any any unreachable
access-list acl_outside permit icmp any any time-exceeded
157
