ping pix inside port is't success
my server(host) connect to pix inside port directly,it can't ping pix success.
there is no host firewall on server.
when i in pix monitor mode .from pix can ping server successful.
how can i resolve this problem?
Gold
Re: ping pix inside port is't success
just wondering if the inside interface is in "shutdown" status.
all interfaces will be in "shutdown" status after performing "write erase".
to verify, do "sh int"
e.g.
interface ethernet1 "inside" is administratively down, line protocol is up
i wonder what different between clear configure and write erase.if they have same result.
thank you for help!
If you want to ping the same interface that you are physicly connected, as your server to the PIX, then you need to configure the "icmp" command.
Ping is not a stateful protocol. To allow pings from the inside to the outside interface you need to create an access-list.
example:
See: Handling ICMP Pings with the PIX Firewall
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
The PIX and the traceroute Command
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00800e9312.shtml
examples:
Traveroute
Microsoft:
access-group 101 in interface outside
access-list 101 permit icmp any host YourPublicIP unreachable
access-list 101 permit icmp any host YourPublicIP time-exceeded
access-list 101 permit icmp any host YourPublicIP echo-reply
UNIX:
ICMP command example
icmp deny any outside
icmp permit any echo-reply outside
icmp permit any echo-reply inside
icmp permit host 192.168.1.30 echo inside
icmp permit host 192.168.1.31 echo inside
icmp permit host 192.168.1.20 echo inside
icmp permit host 192.168.1.40 echo inside
icmp permit host 192.168.1.100 echo inside
sincerely
Patrick
152
