ping problem
I have a pix firewall. The problem I have is when I ping a server in the DMZ, I get the following response in the logs:
305005: No translation group found for icmp src outside:y.y.y.50 dst dmz2:webserver_1 (type 8, code 0)
Just to add I not NATting and my access rule allows pings
Does anyone have any ideas?
Thanks in advance for any help.
Dan
  • Other Security Subjects
Re: ping problem
The log indicates no address translation (address mapping) for your DMZ server from outside interface/segment.
2 ways to allow connectivity to DMZ from inside:
a. Address mapping - configure static NAT for your DMZ server's IP Address to an address belongs to outside/Public segment:
ip address outside 209.165.201.3 255.255.255.224
ip address dmz 172.16.0.1 225 255.255.255.0
static (dmz,outside) 172.16.0.10 209.165.201.10 netmask 255.255.255.255
access-list outside permit icmp any *any
access-group outside in interface outside
where 10.1.1.10 is your DMZ IP, 192.168.1.10 = outside/Public IP
*or change to specific host "host 10.1.1.10"
b. No NAT - do not configure any NAT between DMZ and outside/public segment IF both segments run on same IP subnet, e.g public
ip address dmz 209.165.200.225 255.255.255.0
nat (dmz) 0 209.165.200.225 255.255.255.0
route outside 0.0.0.0 0.0.0.0 1
access-list outside permit icmp any any
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172786.html#wp1113021
Rgds,
AK
Re: ping problem
Thanks for your help with this. Currently I am allowing allowing pings to all servers, and it is working. The difference with this particular IP with which I am having problems with is that it is teamed (win 2003). If I ping it from with in the DMZ I get (DUP) replies. Does this create an issue, if so how can I resolve it? Are there special rules needed with teaming?
Thanks in advance
Dan
99
