Piont to Point VPN Tunnel
gminnis
I need to configure point to point vpn between a PIX 515 E running 6.3(4)code and an ASA 5505 running 7.2. Has anyone seen any documentaion on this?
jmia
Level 7
Level 7
Hi, The following document should help...
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a87f7.shtml
The above document shows how to setup L2L VPN on ASA plus has link to the configuration for PIX 6.0+
Hope it helps, please rate posts if it helps!
The document helped alot. Thanks
Would it be easier to setup easy vpn to do this. I also have a 3000 concentrator.
