I'm attempting to add the maximum interfaces to my brand new 515E-UR and have noticed that the PIX-4FE is end of lifed. Can I use the PIX-4FE-66 66mhz card in the 515E-UR chassis?
Not a problem. You just need to make sure you have the minimum software versions to support this card. Specifically: 5.2(9), 6.0(4), 6.1(4), 6.2(2), 6.3(1) or higher.
Scott
