Pix 501 6.3(5) ICMP and Port forwarding (Help!)
I don't what's going over here.
I just bought this device and spent two days trying to configure the firewall but still don't get success. I can't block icmp traffic using access-list command but can using icmp command.
All redirections don't work on this device. By the way we have Linksys which works fine at our network.
This is simple configuration which doesn't work:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname ssfirewall
domain-name ssoft.lan
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list out2in deny icmp any any
access-list out2in permit tcp any interface outside eq www
access-list out2in permit tcp any interface outside eq https
access-list out2in permit tcp any interface outside eq smtp
access-list out2in permit tcp any interface outside eq 8080
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 216.*.*.85 255.255.255.248
ip address inside 192.168.150.2 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.150.12 255.255.255.255 inside
pdm location 192.168.150.148 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www 192.168.150.148 www netmask 255.255.25
5.255 0 0
static (inside,outside) tcp interface https 192.168.150.148 https netmask 255.25
5.255.255 0 0
static (inside,outside) tcp interface 8080 192.168.150.12 https netmask 255.255.
255.255 0 0
static (inside,outside) tcp interface smtp 192.168.150.12 smtp netmask 255.255.2
55.255 0 0
access-group out2in in interface outside
route outside 0.0.0.0 0.0.0.0 216.*.*.81 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.150.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.150.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxx
: end
[OK]
I played with outbound traffic and did see any problem (aceess-list command has been used)
I can ping 216.*.*.85 interface from anywhere and redirection doesn't work (i can see packets on outside interface when capturing traffic).
I even erased the configuration from the memory and created new from scratch...
Can you explain me what's wrong? I appreciate any help! Thanks
Re: Pix 501 6.3(5) ICMP and Port forwarding (Help!)
Have you try (test for ACL line 1 only):
access-list out2in permit tcp any host 216.*.*.85 eq www
Use IP instead of name 'interface'.
Cheers!
AK
Thanks for the reply.
I started this process using IP address ang got the same result then i changed it to interface outside. The configuration process doesn't look difficult for me at all but i don't understand why it's not working.
Do you know why can i ping 216.*.*.85 from the internet?
I'm just curious if it's possible that i bought a lemon.
Gold
Try the following....
access-list out2in permit tcp any 216.*.*.85 eq www
access-list out2in permit tcp any 216.*.*.85 eq https
access-list out2in permit tcp any 216.*.*.85 eq smtp
access-list out2in permit tcp any 216.*.*.85 eq 8080
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www 192.168.150.148 www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface https 192.168.150.148 https netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 8080 192.168.150.12 https netmask 255.255.255.255 0 0
static (inside,outside) tcp interface smtp 192.168.150.12 smtp netmask 255.255.255.255 0 0
For your SMTP feed, make sure that you MX record for mail also points to IP 216.*.*.85
Also issue: clear xlate after modification and save with: write mem
To stop ICMP probes on your PIX issue:
icmp deny any outside
Hope this helps and if you need any further help let me know - please rate posts if it helps!!
PS. Do you only have the one public IP?
I tried icmp command day ago and it worked.
It doesn't work via ACL.
I have only 1 public ip on this specific device. I used to have such configuration before without any luck.
That's it. It's fixed. The stupid mistake was made inside test environment. We had two internet gateway, The first one is our current gateway the second one used for test purpose. Redirected packets coming in from the test gateway to the servers but servers were set up using another one. Now redirection works (requests and responses should use the same gateway)
215
