pix 501 and cable modem
Distributing pix501 for home use. Some get dhcp address from provider, some don't. Tried shutting off cable modem; no luck. Tried contacting ISP and told nothing special has to be done. Curious thing is that Linksys, standalone PC, and netgear all work.
Thoughts???
1 REPLY
Re: pix 501 and cable modem
What version of code are you using? Check out http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdz09957&Submit=Search and try upgrading to one of the fixed versions and see if it makes a difference (or talk to the ISP and see what their lease time is first).
89
