PIX 501 and H323 - Videoconferencing
I have a H323 terminal behind a PIX 501 with a static mapping to the terminal. I can access the web interface of the terminal from its outside IP, but I cannot make or receive a Video call.
I've enable "fixup protocol H323 1720" and I've even tried the same command opening up other ports needed for h323 (except opening everything from 1024 to 65K).
Any suggestions?
thank you
Patrick Carter
Re: PIX 501 and H323 - Videoconferencing
I don´t know if you are using conduit or access-lists configuration, but what
you need to do is the next:
static (inside,outside) uniqueaddress yourlanaddresswhererunapplication netmask 255.255.255.255 0 0
conduit permit tcp host uniqueaddress eq h323 any
or, if using access-lists:
access-list acl_out permit tcp any host uniqueaddress eq h323
and
access-list acl_in permit tcp any any eq 443
no luck yet. Thank you for the help. Any other suggestions? I tried noth static and conduits and access-lists.
thx
209
