PIX 501 configuration help needed
the genius in our U.S. Head Office decided to replace the Watchguard firewalls in our U.K. office with a Cisco PIX 501, before getting me trained. Therefore I need help!!! At the moment all users can get online as the firewall is setup mainly with the default PAT configuration. However, I have to configure some port redirection for various services. My firewalls external IP is 217.206.x.x and I need:
TCP ports 5631 and 3000 and UDP ports 5632 and 5633 to go to internal IP 192.168.13.1
TCP port 5633 and UDP port 5634 to go to internal IP 192.168.13.21
Please help, my current configration is below:
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxxx encrypted
hostname UKPIX
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol http 3000
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 217.206.x.x 255.255.255.248
ip address inside 192.168.13.2 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 81.168.x.x 255.255.255.255 outside
pdm location 64.208.x.x 255.255.255.255 outside
pdm location 81.168.x.0 255.255.255.255 outside
pdm location 195.137.x.x 255.255.255.255 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 217.206.x.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
http 192.168.13.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 0.0.0.0 0.0.0.0 outside
telnet 81.168.x.x 255.255.255.255 outside
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 64.208.x.x 255.255.255.255 outside
ssh 81.168.x.x 255.255.255.255 outside
ssh 195.137.x.x 255.255.255.255 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
console timeout 0
dhcpd address 192.168.13.3-192.168.13.34 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
username xxxxxxxx password xxxxxxxxx encrypted privilege 15
terminal width 80
Cryptochecksum:xxxx
: end
Thanks.
Gold
Re: PIX 501 configuration help needed
Mick,
What you require is port re-direction on your PIX, have a read of the following document (under port re-direction):
http://www.cisco.com/warp/public/707/28.html
Let me know if this helps or you require further help/advice.
Jay.
Anonymous
N/A
Thanks, this and an email for a colleague have helped me get sorted.
Thanks.
148
