PIX 501 establish IPSEC connection but no data transmission
Hello all,
I got a strange problem with a cisco pix 501 connected remotely to cisco vpn 3000 concentrator.
The pix is configured for remote access session to the concentrator. The problem is that when i make a ping the ipsec tunnel is established and bytes will be transmittet but no or a couple of bytes are recieved by the concentrator.
So I can?t ping the Lan behind the pix.
I do not know what the probelem might be. Both phases are created.
What can be the problem ?
Attached the PIX config.
Best regards
Kai
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside permit ip any any
access-list inside_access_in permit ip any any
pager lines 24
mtu outside 1456
mtu inside 1456
ip address outside pppoe setroute
ip address inside 123.0.0.200 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 123.0.0.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group outside in interface outside
access-group inside_access_in in interface inside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 123.0.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 133.0.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group pppoe_group request dialout pppoe
vpdn group pppoe_group localname *******
vpdn group pppoe_group ppp authentication pap
vpdn username *******
password *********
vpnclient server 111.x.x.200
vpnclient mode network-extension-mode
vpnclient vpngroup vpn password ********
vpnclient username pix password ********
vpnclient enable
terminal width 80
Cryptochecksum:xxxx
: end
1 ACCEPTED SOLUTION
Re: PIX 501 establish IPSEC connection but no data transmission
you're pinging from the network behind the concentrator to devices behind the PIX?
Can you then check if you see data received on the PIX end? You can check that by issueing the command
show crypto ipsec sa
It will tell you per sa how many bytes were received / transmitted.
If you see bytes received and transmitted, and they increase after you issue a ping (usually the increase is 4 packets), you know it's not the pix, but something like nat-traversal that's blocking the return traffic.
There could be different reasons why traffic can't flow through the tunnel.
Based upon the config you've posted I'd first enable IPSEC traffic to bypass the access-lists you've created with the following command (in config mode)
sysopt connection permit-ipsec
Then, you should be able to verify on both endpoints whether the Internet itself is the problem for not flowing traffic. You can do that by checking how many packets are encapsulated/encrypted and decrypted/decapsulated on both sides.
On the pix you can use the command:
and on the concentrator you can use the statistics for that specific tunnel.
Based upon those results you can determine what the actual problem is:
- NAT on the internet (sometimes transparant nat at an ISP)
- MTU Sizes on the internet
- Outbound traffic is blocked on the pix or concentrator (e.g. traffic is not encapsulated)
- Return traffic (the echo-reply) is not sent through the tunnel
Hope this helps
Thank?s for the fast reply.
The command sysopt don?t work with this configuration because the pix tells me that I can?t anter the command when easy vpn is enabled.
The pix itself behaves like a client PC connected to the concentrator.
I will also check on the concentrator for mismatch.
Looking at the head end stats do you see RX bytes for this tunnel? If yes it could be an internal routing issue; check things like tunnel default gateway and other routing if you are doing RRI.
Do other devices pass traffic ok?
If you see no RX bytes it could you that you are blocking esp (protocol 50) at a FW in between (phase one and two IKE are built and maintained on udp port 500 unless using nat-t in which case you'll see data and IKE on udp 4500).
I see bytes transmittet and a much more less bytes recieved. From my windows client I always got an timeout. When I update the stats I see only bytes transmittet.
I?ve checked the filters and rules but it?s always the same as before ( as it works).
The pix operates in the network extension mode with group and username.
Does the pix needs a routing entry when it is connected via ppoe to the internet ?
Hello again,
I made a few test from the pix and the concentrator.
On the pix I?ve checked the whole config and it was ok. I also checked the config on the concentrator and also built up a new vpnuser for the pix but all does not work.
What I found out:
When I make a ping from the concentrator side to the pix (remote) side I see bytes transmitted and only a few recieved by the concentrator.
When I make a ping from a client PC behind a pix I see bytes recieved on the concentrator but only a few transmitted back to the pix.
That?s very strange to me. How can these bytes be lost ?
I made also a debug isakmp:
ISAKMP (0): sending NOTIFY message 36136 protocol 1
crypto_isakmp_process_block:src:133.133.133.133, dest 144.144.144.14
spt:500 dpt:500
ISAKMP processing NOTIFY payload 36137 protocol 1
spi 0, message ID 219159104
recieved DPD_R_U_THERE_ACK from peer 133.133.133.133
return status is IKMP_NO_ERR_NO_TRANS
Hope this helps. I got no more ideas.
p.S.: May it be possible that the ISP changed something at the DSL connection that could impair/harm the tunnel ?
P.P.S: I also made a show ipsec sa but no bytes were recieved.
I?ve checked also the tunnel sh isakmp sa and tells me that 2 tunnels are established. One from the offical Ip from the provide the pix gets and one for the network behind the concentrator
Have a nice weekend
Kai
Hello all.
it?s working ! Do not ask me why I did not changed anything. I just checked it one more time and it?s working
Could it be that ths ISP cheanged sonething ?
anyway thanks a lot for your help
Best regards
Kai
208
