PIX 501 NAT translation for VPN traffic problem
I need to:
make ACL from 172.24.159.108 to host 192.168.50.83 and 192.168.50.86
NAT interesting traffic to 172.24.159.0 255.255.255.0
Phase 1
Authentication: Pre-Shared
Encryption: 3DES
Hash: SHA
DH: 1
Lifetime: 86400 sec
Pre-shared Key: ************
Phase2
ESP encryption 3DES
ESP authentication
Lifetime 28800
I have been struggling with this for 2 weeks. Any ideas what I am doing wrong?
Config is attached.
Thanks in advance!!!!
Ryan
Green
Re: PIX 501 NAT translation for VPN traffic problem
Config looks ok. You are policy nating 192.168.0.108 to 172.24.159.x when going to 192.168.50.83 and 86. You have then defined the natted address in your interesting traffic acl. You should be able to remove this command.
no static (inside,outside) 172.24.159.0 access-list conditional_nat 0 0
clear xlate
ok made the change and here is new config, still no traffic after clear xlate.
sh cry isakmp sa doesn't show that the tunnel is even connecting, could my problem lie with something other than the ACL and NAT config?
new config
Silver
nat (inside) 3 access-list conditional_nat 0 0
global (outside) 3 172.24.159.1-172.24.159.254 netmask 255.255.255.0
Is this policy nat translation actually working ? Do you see translations when you do show xlate ?
actually it doesn't look like it is, should I go back to my static translations? I had that in place at one time but since changed to dynamic to get this to work.
any ideas?
Silver
ok so problem is that Policy nat is not working. You can try static policy nat also.
Check and post results .
Saju
Silver
Saju
ok, im back to static NAT. Here is the results of sh xlate
PAT Global 166.XXX.XXX.XXX(13815) Local 192.168.0.108(2101)
PAT Global 166.XXX.XXX.XXX(7666) Local 192.168.0.112(2720)
PAT Global 166.XXX.XXX.XXX(13816) Local 192.168.0.82(2720)
PAT Global 166.XXX.XXX.XXX(13817) Local 192.168.0.112(3642)
PAT Global 166.XXX.XXX.XXX(13818) Local 192.168.0.11(1494)
PAT Global 166.XXX.XXX.XXX(14785) Local 192.168.0.112(1199)
PAT Global 166.XXX.XXX.XXX(2) Local 192.168.0.112 ICMP id 512
PAT Global 166.XXX.XXX.XXX(14876) Local 192.168.0.112(1251)
PAT Global 166.XXX.XXX.XXX(14724) Local 192.168.0.108(2735)
PAT Global 166.XXX.XXX.XXX(7553) Local 192.168.0.108(15346)
PAT Global 166.XXX.XXX.XXX(14732) Local 192.168.0.108(2744)
Global 172.24.159.0 Local 192.168.0.108
Here is the Debug output as well.
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 2 against priority 40 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash SHA
ISAKMP: default group 1
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP (0): atts are not acceptable. Next payload is 0
ISAKMP (0): Checking ISAKMP transform 2 against priority 60 policy
ISAKMP: hash SHA
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): processing vendor id payload
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
return status is IKMP_NO_ERROR
crypto_isakmp_process_block:src:66.XXX.XXX.XXX, dest:166.XXX.XXX.XXX spt:500 dpt:500
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): received xauth v6 vendor id
ISAKMP (0): speaking to another IOS box!
ISAKMP (0): speaking to a VPN3000 concentrator
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
OAK_MM exchange
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): processing keep alive: proposal=32767/32767 sec., actual=10/30 sec.
ISAKMP (0): remote peer supports dead peer detection
ISAKMP (0): SA has been authenticated
ISAKMP (0): beginning Quick Mode exchange, M-ID of 368405633:15f56c81
ISAKMP (0): sending INITIAL_CONTACT notify
ISAKMP (0): sending NOTIFY message 24578 protocol 1
VPN Peer: ISAKMP: Added new peer: ip:66.XXX.XXX.XXX/500 Total VPN Peers:2
VPN Peer: ISAKMP: Peer ip:66.XXX.XXX.XXX/500 Ref cnt incremented to:1 Total VPN P
eers:2
ISAKMP (0): processing NOTIFY payload 14 protocol 3
spi 0, message ID = 719581143
return status is IKMP_NO_ERR_NO_TRANS
ISAKMP (0): processing DELETE payload. message ID = 2042020179, spi size = 16
ISAKMP (0): deleting SA: src 166.XXX.XXX.XXX, dst 66.XXX.XXX.XXX
ISADB: reaper checking SA 0xcb9ca4, conn_id = 0 DELETE IT!
VPN Peer: ISAKMP: Peer ip:66.XXX.XXX.XXX/500 Ref cnt decremented to:0 Total VPN P
eers:2
VPN Peer: ISAKMP: Deleted peer: ip:66.XXX.XXX.XXX/500 Total VPN peers:1
ISADB: reaper checking SA 0xb8f26c, conn_id = 0
Thanks in advance!
Silver
Can you post remote end's vpn config also? The SA actually builds up and then gets deleted.
Check Transform set, crypto acl (mirror image of other side) etc.
Saju
Pls rate if it helps
Silver
You can try doing policy nat to single ip :
global (outside) 3 172.24.159.1 netmask 255.255.255.255
or
static (inside,outside) 172.24.159.1 access-list conditional_nat 0 0
Added "static (inside,outside) 172.24.159.108 access-list conditional_nat 0 0"
and removed
"static (inside,outside) 172.24.159.0 access-list conditional_nat 0 0"
ISAKMP (0): beginning Main Mode exchange
OAK_MM exchange
ISAKMP: hash SHA
ISAKMP: hash SHA
OAK_MM exchange
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
OAK_MM exchange
ISAKMP (0): beginning Quick Mode exchange, M-ID of 176378872:a8353f8IPSEC(key_en
gine): got a queue event...
IPSEC(spi_response): getting spi 0x942c64b8(2485937336) for SA
from 66.XXX.XXX.XXX to 166.XXX.XXX.XXX for prot 3
eers:2
spi 0, message ID = 2816305469
ISAKMP (0): processing DELETE payload. message ID = 3032362312, spi size = 16
ISADB: reaper checking SA 0xba108c, conn_id = 0 DELETE IT!
eers:2
VPN Peer: ISAKMP: Deleted peer: ip:66.XXX.XXX.XXX/500 Total VPN peers:1IPSEC(key_
engine): got a queue event...
IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
IPSEC(key_engine_delete_sas): delete all SAs shared with 66.XXX.XXX.XXX
sh xlate shows "Global 172.24.159.108 Local 192.168.0.108" now as well.. any ideas?
Thanks again
Silver
Cool!
Saju
I don't have access to the other end, only thing I have is these instructions.
remote endpoint is: 66.179.80.108
remote network is: 192.168.50.0 (255.255.255.0)
Clinic will need to make ACL from 172.24.159.108 to host 192.168.50.83 and 192.168.50.86
Clinic will need to NAT interesting traffic to 172.24.159.0 255.255.255.0
Phase 1
Encryption: 3DES
Hash: SHA
DH: 1
Lifetime: 86400 sec
Pre-shared Key: *****************
Phase2
ESP encryption 3DES
ESP authentication
Lifetime 28800
230
