Pix 501 PPPOE outside
I have a pix 501.
It obtains its IP from the ISP via PPPOE.
If I have a mail server on the inside can I still NAT mail to that device.
I have done NAT before to mail servers where I have an allocation of IP's from the ISP.
In this scenario I only have 1 IP (it does not change) outside.
Can I allow other services in also even if I have 1 IP
John
1 ACCEPTED SOLUTION
Re: Pix 501 PPPOE outside
The config is OK, but it might be better to replace the fixed IP address in the access-list and the staic with a dynamic one.
1 - You have configured:
access-list outside_access_in permit tcp any host XX.XX.XXX.XXX eq ftp
access-group outside_access_in in interface outside
static (inside,outside) tcp XX.XX.XXX.XXX ftp ftpserver ftp netmask 255.255.255.255 0 0
2. - I would replace this with:
access-list outside_access_in permit tcp any interface outside eq ftp
static (inside,outside) tcp interface ftp ftpserver ftp netmask 255.255.255.255 0 0
The advantage of this setup is that if ever the IP changes the NAT and access-list will change automticly too.
3.- You need to to a CLEAR XLATE after you have changed the NAT settings.
clear xlate
Note that this will reset all connections.
4.- Use a dyndns or no-ip client so when you connect from the Internet you just have to know the DNS name and if the IP changes the client will update the DynDNS server.
See:http://www.no-ip.com/downloads.php
5.- Are you sure that your ISP Internet Service Provider is allowing ftp, smtp and http ? A lot of providers block this ports for non commercial DSL connections !!
sincerely
Patrick
I think thats possible by putting a static command an ACl to permit SMTP.
Yes you can do this with a port forward command in a the static command.
Here is an example:
ip address inside 192.168.1.1 255.255.255.0
access-list acl_out permit tcp any interface outside eq smtp
access-group acl_out in interface outside
static (inside,outside) tcp interface smtp 192.168.1.10 smtp netmask 255.255.255.255 0 0
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 Gateway 1
sincerley
Patrick
Hi I tried that and i did not work any other ideas
Here is a my current config. For ease of testing I tried to allow ftp in to connect to an ftpserver on the inside.
Can someone tell me what I am doing wrong
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password *******************
passwd ****************** encrypted
hostname pixfirewall
domain-name ***************
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.1.100 ftpserver
access-list inside_outbound_nat0_acl permit ip any 10.200.200.192 255.255.255.224
access-list outside_cryptomap_dyn_20 permit ip any 10.200.200.192 255.255.255.224
access-list outside_access_in permit tcp any host XX.XX.XXX.XXX eq ftp (X= the IP assigned by ISP via PPPOE)
pager lines 24
logging console debugging
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip audit info action alarm
ip audit attack action alarm
ip local pool RasIP 10.200.200.200-10.200.200.210
pdm location 0.0.0.0 255.255.255.255 inside
pdm location 192.168.1.0 255.255.255.0 inside
pdm location ftpserver 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_outbound_nat0_acl
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication LOCAL
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup ras address-pool RasIP
vpngroup ras dns-server 159.134.237.6 192.111.39.1
vpngroup ras default-domain ************
vpngroup ras idle-time 1800
vpngroup ras password ********
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 60
ssh timeout 5
management-access inside
console timeout 0
vpdn group pppoe_group request dialout pppoe
vpdn group pppoe_group localname eircom
vpdn group pppoe_group ppp authentication chap
vpdn username eircom password ********* store-local
dhcpd address House1-192.168.1.120 inside
dhcpd dns 159.134.237.6 159.134.248.17
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
username name*** password xxx privilege 15
username name2**** password xxx privilege 15
terminal width 80
john
clear xlate
sincerely
Patrick
works perfectly when you do it through command line.
does work if you set it up through PDM. PDM wants you to configure nat for the host inside
299
