PIX 501 Site to Site VPN Help
I'm pretty new to PIX firewalls, so I hope that somebody on here can assist me.
I have two PIXs and am trying to create a VPN between the two PIX. I have posted the configs below.
The problem lies that on PIX One I can ping PIX Two, but I can't ping any servers behind PIX TWO. On PIX Two I can't ping PIX ONE or any servers behind it.
Any advise would be appreciated.
PIX ONE
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname TMAXWALES
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list inside_outbound_nat0_acl permit ip 192.168.254.0 255.255.255.0 192.1
68.1.0 255.255.255.0
access-list outside_cryptomap_20 permit ip 192.168.254.0 255.255.255.0 192.168.1
.0 255.255.255.0
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside ***.*.198.139 255.255.255.248
ip address inside 192.168.254.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.254.10 255.255.255.255 inside
pdm location 192.168.1.0 255.255.255.0 outside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 ***.*.198.137 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.254.10 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 20 ipsec-isakmp
crypto map outside_map 20 match address outside_cryptomap_20
crypto map outside_map 20 set peer ***.*.198.138
crypto map outside_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
isakmp enable outside
isakmp key ******** address ***.*.198.138 netmask 255.255.255.255 no-xauth no-co
nfig-mode
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
telnet timeout 5
ssh timeout 5
terminal width 80
PIX TWO
PIX Version 6.2(2)
hostname tmaxbangor
names
access-list inside_outbound_nat0_acl permit ip 192.168.1.0 255.255.255.0 192.168
access-list outside_cryptomap_20 permit ip 192.168.1.0 255.255.255.0 192.168.254
.0 255.255.255.0
pager lines 24
logging on
logging buffered debugging
mtu outside 1500
mtu inside 1500
ip address outside ***.*.198.138 255.255.255.248
ip address inside 192.168.1.1 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit info action alarm drop reset
ip audit attack action alarm drop reset
pdm location 192.168.1.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.84.7.111 255.255.255.255 inside
http 192.168.1.10 255.255.255.255 inside
floodguard enable
crypto map outside_map 20 set peer ***.*.198.139
isakmp key ******** address ***.*.198.139 netmask 255.255.255.255 no-xauth no-co
nfig-mode
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 50
ssh timeout 5
terminal width 80
1 ACCEPTED SOLUTION
Re: PIX 501 Site to Site VPN Help
Can't see anything obviously wrong with the configs. Do you have these connected back to back on the same subnet, it looks like it even though you've xxx'd out the IP addresses? If so it might just be a routing issue, in that they're sending everything to the default gateway of xxx.x.198.137 rather than to each other.
Try adding a static route for the remote subnet into each PIX that directly points to the peer, so on PIX1 you'd have:
route outside 192.168.1.0 255.255.255.0 xxx.x.198.138
and on PIX2 do:
route outside 192.168.254.0 255.255.255.0 xxx.x.198.139
and see if that makes any difference. Note that you wouldn't run into this issue when both PIX's are on separate networks and use their default gateway for all their routing decisions.
If that still fails, run "debug cryp isa" and "debug cry ipsec" on both PIX's and then try and build a tunnel again, then send us the output.
Also, make sure in your testing that you're pinging from a host behind one PIX to a host behind the other PIX, don't ping from PIX to PIX or from host to PIX cause that won't test your VPN connectivity.
1 REPLY
and on PIX2 do:
118
