PIX 501 to PIX 501 IPSEC VPN Help!
I apologize before hand for what may be a very long post. What I'm trying to do right now, is create a IPSEC VPN at home to test the functionality of the PIX site-to-site VPN. The problem is, whenever I send interesting traffic through the PIX to establish the VPN, I get the following messages via debug isakmp:
VPN Peer: ISAKMP: Added new peer: ip:10.21.21.2 Total VPN Peers:1
VPN Peer: ISAKMP: Peer ip:10.21.21.2 Ref cnt incremented to:1 Total VPN Peers:1
ISAKMP (0): beginning Main Mode exchange
ISAKMP (0): retransmitting phase 1...IPSEC(key_engine): request timer fired: count = 1,
(identity) local= 10.20.20.2, remote= 10.21.21.2,
local_proxy= 10.20.20.2/255.255.255.255/1/0 (type=1),
remote_proxy= 10.21.21.2/255.255.255.255/1/0 (type=1)
ISAKMP (0): deleting SA: src 10.20.20.2, dst 10.21.21.2
ISADB: reaper checking SA 0x809f94d0, conn_id = 0 DELETE IT!
VPN Peer: ISAKMP: Peer ip:10.21.21.2 Ref cnt decremented to:0 Total VPN Peers:1
VPN Peer: ISAKMP: Deleted peer: ip:10.21.21.2 Total VPN peers:0IPSEC(key_engine)
: request timer fired: count = 2,
The net result is that I get no connectivity between the two locations. Any help in troubleshooting this would be appreciated. The configs I have setup on the PIXes are below.
My physical set up is as follows:
Host #1 (192.168.1.2) --> (192.168.1.1) PIX #1(10.20.20.2) --> (10.20.20.1) Router (10.21.21.1) --> (10.21.21.2) PIX #2 (10.22.22.1) --> (10.22.22.100) Host #2
Configs:
PIX #1
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
access-list 101 permit icmp host 10.20.20.2 host 10.21.21.2
access-list 101 permit tcp host 10.20.20.2 eq telnet host 10.21.21.2
ip address outside 10.20.20.2 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 10.20.20.2 192.168.1.2 netmask 255.255.255.255 0 0
conduit permit icmp any 10.21.21.0 255.255.255.0
conduit permit icmp any 10.20.20.0 255.255.255.0
conduit permit tcp any eq telnet 10.21.21.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 10.20.20.1 1
crypto ipsec transform-set cisco esp-3des esp-md5-hmac
crypto map delta 10 ipsec-isakmp
crypto map delta 10 match address 101
crypto map delta 10 set pfs group2
crypto map delta 10 set peer 10.21.21.2
crypto map delta 10 set transform-set cisco
crypto map delta interface outside
isakmp enable outside
isakmp key ******** address 10.21.21.2 netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
PIX #2
PIX Version 6.1(4)
access-list 100 permit icmp host 10.21.21.2 host 10.20.20.2
access-list 100 permit tcp host 10.21.21.2 host 10.20.20.2 eq telnet
ip address outside 10.21.21.2 255.255.255.0
ip address inside 10.22.22.1 255.255.255.0
static (inside,outside) 10.21.21.2 10.22.22.100 netmask 255.255.255.255 0 0
conduit permit tcp host 10.21.21.2 eq 8000 any
route outside 0.0.0.0 0.0.0.0 10.21.21.1 1
crypto map disco 10 ipsec-isakmp
crypto map disco 10 match address 102
crypto map disco 10 set pfs group2
crypto map disco 10 set peer 10.20.20.2
crypto map disco 10 set transform-set cisco
crypto map disco interface outside
isakmp key ******** address 10.20.20.2 netmask 255.255.255.255
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
Thanks in advance for any help!
-- Andy
Re: PIX 501 to PIX 501 IPSEC VPN Help!
Your connection is failing on Phase 1. I would add "sysopt connection permit-ipsec" to each config. That should dix it. If it doesn't, I would look at this config example: http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094761.shtml .
If that doesn't help let us know and we can do other the debugs.
Steve
Thanks Steve. I'll give that a try tonight.
--Andy
I'm happy to say the issue has been resolved. While adding the extra command to my config didn't fix the problem, clearing my settings and starting from scratch based on the config example worked beautifully. Thanks again Steve!
91
