01-09-2003 05:44 AM - edited 02-20-2020 10:28 PM
So, if the 4 ports are a 10-100 switch:
1. Why are all 4 ports "seen" as a single interface/port? What
if I want to shutdown access to 3 of the 4 ports?
2. Why does the OS say the 4-port interface can only be set to
10 Mbps full-duplex? Why not be able to config on a port-by-port basis?
Some clarification on these questions would be helpful.
Scott
01-09-2003 05:48 AM
I believe it just does dhcp.
01-10-2003 12:44 AM
an answer to you first question. Imagine you have a pix with one outside interface and one inside interface and a 4-port switch connected to this inside interface. This pix 501 puts this together in the same device.
This also answers your second question, you can only configure the 'virtual' inside interface of the pix. The real physical inside interface is provided by a fast ethernet 10/100 switch.
Kind Regards,
Tom
01-27-2003 03:40 AM
Scotthale-
The Pix501 only has two interfaces; Interface0;Interface1. Interface0 being the outside interface and Interface1 being the inside interface. Interface1 is comprised of the 4 port switch. The switch is not managed except for the interface so you get an auto config negotiation for each port.
The Pix 501 wasn't desinged like the Pix 520 which you can have more then two interfaces. If you really need to accomplish control of more then two ports (like for a DMZ) then you will need a higher pix model.
I'm sure Cisco could better ansewer the design rational behind the PIX 501.
I hope the information provided helped.
Sincerely-
Mark English
