PIX 501 with PPPOE and IPSEC
I am using a pix 501 firewall with ios 6.2(2), I currently have it configured to use PPPOE over a DSL connection. Is there a way i can configure IPSEC or L2TP over this connection even if the ip address changes with PPPOE?
Thanks in advance,
bb
Re: PIX 501 with PPPOE and IPSEC
Try:
isakmp identity hostname
When two peers use IKE to establish IPSec security associations, each peer sends its ISAKMP identity to the remote peer. It will send either its IP address or host name depending on how each has its ISAKMP identity set. PIX by default uses IP. In your case as the IP may change, use hostname instead. The rest of the PIX ipsec can be set up as normal. Then set the other end to accept dynamic connections (eg for PIX: isakmp key ******** address 0.0.0.0 netmask 0.0.0.0).
Hope that helps.
Steve
Thanks, I try it later today.
bb
92
