Pix 506 and port translation issue
am running a pix 506 3.6(3) to gain Internet access to my remote office users. And in the same time users are connected to the main office via Lan –to Lan ipsec tunnel. The pix is connected to the Internet with ADSL line (ISP). The pix is also distributing private ip address to hosts behind pix. The question is, how can I access the a internal host behind a pix from outside world with using the pix external ip address with predefined port numbers? The meaning is when I write in browser 80.33.163.31:8081 than pix has to port translate (8081) to the designated hosts internal ip address.
Tanks in advance
Sfanayei
1 REPLY
Re: Pix 506 and port translation issue
yes you can use port translation the commands are
static (inside,outside) tcp 8081 8081 netmask 255.255.255.255
You can create as many entries as you like for the same Public adddress as long as the ports used for the connection is different.
Please rate it is you find it useful
272
