Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Pix 506 and static routing on trusted interface
I have recently buy one Cisco Pix 506.
Is more day I search to configure a static route in a internal interface but not works?
The internal interfaced is configured 192.168.1.2 255.255.255.0
The esternal interface is configured 85.x.162.194 255.255.255.248 default gateway is 85.x.162.193
My problem is made a static route for when at the internal interface arrive the request pachet IP in this range (192.168.0.0 255.255.255.0) the router send this pachet to a default gateway in the inside interface (Gateway 192.168.1.2 255.255.255.0)
I past this configuration for explain but not works L
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address inside 192.168.1.7 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.0.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.x.x.42.162.193 1
route inside 192.168.0.0 255.255.255.0 192.168.1.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.50-192.168.1.100 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:xxx
: end
pixfirewall(config)#
This configuration works, but in old Cisco 837 and no give me problem:
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip route 192.168.0.0 255.255.255.0 192.168.1.1
ip route 192.168.2.0 255.255.255.0 192.168.1.1
ip route 192.168.3.0 255.255.255.0 192.168.1.1
But whit this firewall non works?..
Please help me becouse I want implemente this firewall but no found a good configuration.
Thanks in advanced!
Re: Pix 506 and static routing on trusted interface
Your ip address for the outside interface is missing. Is it a typo error?
Anyway, from where do you expect the network traffic destine for 192.168.0.0 255.255.255.0 originates/comes from? Is it coming from the inside interface itself, arrived at PIX inside interface (ethernet 0) and you expect PIX to send/route it to 192.168.1.1? This is based on your old C837 router config.
What is the router with IP of 192.168.1.1 routing configuration statement looks like that made it send the traffic (192.168.0.0/24) to 192.168.1.2? Can you post the config?
FYI, it is totally different when you used router to do routing compared to PIX. Router is intelligent to do routing, but not PIX, e.g redirecting traffic from an interface to another or other devices.
Rgds,
AK
For You is correct this observation????
I hope is not corret :-(
Thanks!
The PIX is not a router in the sense you want to use it.
"route inside ....... " will route packets coming from the outside to a
valid inside gateway,
but it will not reroute packets coming from the inside back to an inside
gateway.
So if your PC have the PIX as the default gateway , you cannot reroute some
packets to the
VPN concentrator. You will need either another router or a static route
on the PC.
I am trying to understand your question.
Where this network traffic destine for 192.168.0.0 255.255.255.0 originates/comes from?
Rgds,
AK
sorry for my bad english...
The static route I wont works when a machine connect in a trusted zone of pix, call a IP in different subnet and for go to this subnet the statir route send the request to one internal trusted gateway example 192.168.1.1.
I hope you understand...
call to pix in a trusted, pix have a static ropute for a definite subnet and the trusted interface send the call to another default gateway.
Thanks in advanced!!!
Up Up Up
THANKS!
Is it solved/working now?
Rgds,
AK
NO :-(
But i have read in the manual of the command, ther eis one command for made a static route and is:
route and there is one example clear for undestand the static route:
route dmz 192.168.42.0 255.255.255.0 192.168.1.5 1
But when i modifi this command for add at my router the router give me error...
Please help me :-(
You don't have a dmz.
Your observation is correct: the PIX will not redirect packets from the inside to the inside.
To get round this, use 192.168.1.1 (the internal router) as default gateway for all hosts on 192.168.1.x. Do not use the PIX as your default gateway.
246
