PIX 506 E (6.2.2) and VPN client 3.5.4 (Win 98ME) problems
Hi All,
I have a problem with the configuration of the VPN, The same configuration on a PIX 515 has no problems.
I have turned on the deb crypto isakmp, but no packet are received from the pix.
Consider that I am using the pix to browsing internet and the pix is reacheble from internet using the SSH
The pix configuration:
access-list 130 permit ip 192.168.0.0 255.255.255.0 10.0.10.0 255.255.255.0
ip local pool vpndevice 10.0.10.1-10.0.10.10
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set device esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set device
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp client configuration address-pool local vpndevice outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
vpngroup test address-pool vpndevice
vpngroup test dns-server XX.XX.XX.XX
vpngroup test default-domain XXXXXXXX
vpngroup test idle-time 1800
vpngroup test password XXXXXXXX
Thanks a lot
Bronze
Re: PIX 506 E (6.2.2) and VPN client 3.5.4 (Win 98ME) problems
please post your complete pix config, your above crypto config looks good.
check the following:
1 - make sure that you have - nat (inside) 0 access-list 130
2 - make sure that all your PCs sitting behind the pix point to it as default gw
or know how to reach to 10.0.10.0/24 network.
3- if u have any acl on the inside interface, make sure permit your traffic.
Thx
Afaq
Hi Afaq,
on client side it seems that the peer does not responding,
on server side enabling the crypto isakamp no packet are received-
I have enabled the ipsec on outside interface..
Would you tell me if ther are some command that I can digit to enable the debug message on ssh remote terminal?
Ok for the nat access list,
no problems for the pc behind the firewaa, because no key are exchange, so I suppose the problems cames first.
Non acl on inside interface....
Let me know as soon as possible
Bye GV
87
