Pix 506 VPN connections issues
We are using a pix 506 trying to establish a VPN to allow harddrive mapping and are experiencing multiple issues. I have 3 successful connections and several unsuccessful. The unsuccessful ones are:
1-win2000 machine, dsl, can get on the internet but when trying to get to the pix the remote peer is not available. cannot ping although can ping other internet machines
2-xp pro machine, dial-up, can vpn and connect to the pix, cannot ping once inside and therefore unable to map drive
3-xp pro machine, dial-up, can vpn and ping, cannot map a drive. cannot find drive.
4-xp pro machine, dial-up, can find the pix but cannot establish a secure connection.
any comments are appreciated. thanks.
Re: Pix 506 VPN connections issues
May be it could be a MTU issue, Try lowering the MTU with a utility called DR. TCP. The link is
below.
http://www.dslreports.com/front/drtcp.html
If the Win2000 is not able to make a connection to the Pix, run:
Debug crypto isakmp
Debug crypto ipsec on the pix
Logs from the client and look through them to see where the client is failing to make a connection.
If the client is able to make a connection and not able to pass traffic, then check to see if the client is connecting from behind a PAT Device. Look at the statistics on the client side and also the encrypts/decrypts on the pix to see if the pix receives the packets.
If you can ping the internal ip addresses, then there is IP Connectivity. Regarding mapping a drive, you need to make sure that Wins server information is pushed to the client and also check and see if the client can ping the Wins server.
If the xp-pro is not able to make a connection to the Pix, run:
Debug crypto isakmp
Arul
I have a similar problem. We have a PIX 515E installed that I cannot ping from a workstation on a dsl connection. I can ping other company VPN devices (but these are not PIX)
With the log viewer open I get the following error :-
1 11:34:50.882 02/14/03 Sev=Warning/3 DIALER/0xE3300015
GI VPN start callback failed "CM_CTCP_FAIL" (1Dh).
158
