Pix 506E and OWA
Hi All,
I am having an issue with Pix 506E.
The pix is running fine, but the owner wants Exchange
2000 Outlook Web Access configure. So He can receive
e-mails from anywhere.
Anyways, I got it working and it runs good.
But then no one can access internet anymore.
I want to set it up where they can access internet
and use Exchange OWA..
Here is my before and after Pix configuration.
Thanks for all your help..
This is the before OWA configure.
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxx
passwd xxxxxx
hostname Pix506
domain-name wfgfactor.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.66 255.255.255.240
ip address inside 10.0.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface smtp 10.0.0.2 smtp netmask 255.255.255.255
0 0
conduit permit tcp host x.x.60.66 eq smtp any
route outside 0.0.0.0 0.0.0.0 207.215.60.66 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 10.0.0.2 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:xxxxxxx
This is the one that works for OWA.
The only difference is the STATIC commands and
access-list
PIX Version 6.1(4)
passwd xxxxx
hostname Pix506
names
access-list 100 permit tcp any host 207.215.60.66 eq smtp
access-list 100 permit tcp any host 207.215.60.66 eq www
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside x.x.xx 255.255.255.240
pdm history enable
arp timeout 14400
static (inside,outside) x.x.x.66 10.0.0.2 netmask 255.255.255.255 0 0
access-group 100 in interface outside
http server enable
floodguard enable
telnet 10.0.0.2 255.255.255.255 inside
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
terminal width 80
thank you,
-Paul Hong
  • Other Security Subjects
Silver
Re: Pix 506E and OWA
0 0
This works because you forward a port to the smtp port
static (inside,outside) tcp interface www 10.0.0.2 www netmask 255.255.255.255
0 0
Is what you want to add. Get rid of
static (inside,outside) 207.215.60.66 10.0.0.2 netmask 255.255.255.255 0 0
This statically binds that ip address to the server, so only the server can effectively use it. Thus, you clients do not have an address their traffic can be PAT'd to.
So, add the one static, delete the other one, and issue a "clear xlate". Everything should work
Thank you so much.
It worked like a charm and I finally got it
fixed.
I had to add a command in addition to that
in order to make it work:
conduit permit tcp host 207.215.60.66 eq www any
Thanks again.
-Paul Hong
287
