Community Member
PIX 506e problem with FTP external access
I try to configure the PIX today and all running correctly but I need to accede from outsite to inside via ftp and is imposible, return me some error.
The configuration is basic:
BCN-ROU-WAN1# sh run
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx encrypted
passwd xxx encrypted
hostname BCN-ROU-WAN1
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
access-list outside_access_in permit tcp any eq ftp any eq ftp
pager lines 24
icmp permit any outside
mtu outside 1500
mtu inside 1500
ip address outside
ip address inside
ip audit info action alarm
ip audit attack action alarm
pdm location inside
pdm location inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0 0
static (inside,outside) tcp ftp ftp netmask 0 0
access-group outside_access_in in interface outside
route outside 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication telnet console LOCAL
ntp server source outside prefer
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
username xxxx password xxxxx
privilege 15
terminal width 80
banner login Red interna de Planet Screen Networks. Toda accion delictiva contra este acceso sera perseguido judicialmente.
: end
Please can somebody help me with this problem?
Thanks a lot,
Re: PIX 506e problem with FTP external access
the issue maybe related to the acl, "access-list outside_access_in permit tcp any eq ftp any eq ftp"
the reason being that the source port will be a random port (usually >1023).
modify the acl without specifying the source port.
access-list outside_access_in permit tcp any host xx.xx.62.98 eq ftp
Community Member
hello jackko,
Thanks a lot for your support. The reason is this.
I change it and running without any problem.
Thanks again,
it's good to learn that your issue has been resolved.
according to cisco,
Why should I rate posts?
If you see a post that you think deserves recognition, please take a moment to rate it.
You'll be helping yourself and others to quickly identify useful content -- as determined by members. And you'll be ensuring that people who generously share their expertise are properly acknowledged. As posts are rated, the value of those ratings are accumulated as "points" and summarized on the Member Profile page and on each member's Preferences page.
