PIX 506E virtual interface
arvindsa
I have PIX 506E with version 6.3(1). I'm creating virtual interface on this but getting following error:
[ERR]interface ethernet1 vlan13 logical
Interface limit (2) reached.
Unable to create logical interface.
Internal Error: Unable to initialize logical interface.
[ERR]nameif vlan13 virt security99
For physical interace, please use hardware_id as specified in
interface command, instead of vlan_id. E.g. ethernet0, ethernet1 etc.
[ERR]ip address virt 192.168.102.5 255.255.255.0
Command failed
VLAN we already creted on cisco switch. do I need add anything on switch or firewall
Fernando_Meza
Level 7
Level 7
Hi ... unfortuantely my friend logical interfaces are not supported on your platform.
Cisco Secure PIX Model Total Interfaces Physical Interfaces Logical Interfaces
501 2 2 Not supported
506E 2 2 Not supported
515E 10 6 8
525 12 8 10
535 24 10 22
NOTE VLANs are not supported on the PIX 501 and PIX 506/506E.
I hope it helps ... please rate it if it does !!!
main problem is solved by upgrading to 6.3(5) version. PIx 506E supports Virtual Interface. Now I am facing routing problem:
[1] Pix default inside int is 192.168.101
[2] Pix virtual int is now 192.168.102..
I am not able to ping 192.168.102 from my machine(192.168.101.)
