Pix 515 and IPV6
llexuss
I have a pix 515 with 3 interfaces running pix software 7.1(1)
e0 outside 3ffe:xxxx::101/64
e1 frontporch 3ffe:xxxx:1:101/64
e2 inside 3ffe:xxxx:2:101/64
All interfaces have ipv6 enabled and neighbor discovery disabled and router advertisment is suppressed.
I would like to host a web server on the frontporch zone of the firewall.
I need the webserver to be accessable via ::/0 (the internet) as well as the inside 3ffe:xxxx:2::/64
I added the following access list
ipv6 access-list incoming permit tcp any eq www host 3ffe:xxxx:1::a6a6
access-group incoming in interface outside
What else am I missing?
for debugging, I added another access list with icmp enabled
ipv6 access-list incoming permit icmp6 any any
from the inside address I can communicate with the outside ::/0 (sprintv6.net) but am unable to communicate with hosts on the frontporch. from the outside or inside.
Firefox can't establish a connection to the server at [3ffe:xxxx:1::a6a6]
the security levels are 0 for ouside
10 for frontporch and 100 for inside.
Any advice you could offer would be benificial.
a-gould
looks like you can't get to the server since the source is "any eq www" ....which isn't the case.  the source would be some dynamically generated tcp port....it's the destination that is eq www....  so probably should be....
ipv6 access-list incoming permit tcp any host 3ffe:xxxx:1::a6a6 eq www
