PIX-515 does not identify Tokenring Interfacecard
I have installed a PIX-1TR interface in PIX-515.Boot ok, configuration 'answer' NO. sh vers and sho int etc. shows only the build in Ethernet0 and Eth1, but not tokenring interface.
sh version output looks as follow.
Thanks Ruedi
pixfirewall# sh ver
Cisco PIX Firewall Version 6.2(2)
Cisco PIX Device Manager Version 2.0(2)
Compiled on Fri 07-Jun-02 17:49 by morlee
pixfirewall up 10 mins 14 secs
Hardware: PIX-515, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0003.6bf6.a8a9, irq 11
1: ethernet1: address is 0003.6bf6.a8aa, irq 10
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 3
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
Serial Number: 405341167 (0x182903ef)
Running Activation Key: xxxxxxxxx
Configuration last modified by enable_15 at 13:11:47.490 UTC Tue Dec 23 2003
pixfirewall#
2 ACCEPTED SOLUTIONS
Re: PIX-515 does not identify Tokenring Interfacecard
TokenRing is no longer supported, I think since version 6.0.
For documentation purposes:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_60/relnotes/pixrn601.htm#xtocid66
The previous poster was right on the money.
Scott
Scott
Hi Andre and Scott,
Thanks for informations.
Problem solved.
Ruedi
81
