Pix 515 not starting - Very Ugent
Pix model: 515E
OS Version: 6.3(3)
Trying to connect through consule. System stuck after the following msg:
CISCO SYSTEMS PIX FIREWALL
Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73
Compiled by morlee
32 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
00 11 00 8086 1229 Ethernet 11
Any one pls help as urgent basis
Quick response pls
Reza
Network Administrator
karimmr@ebl-bd.com
Re: Pix 515 not starting - Very Ugent
Hello Reza,
Were there any recent changes to the Pix? Was this Pix ever operational?
Initial thinking is perhaps you have corrupt OS. If so, do you want to re-image the Pix via monitor mode?
Here are some instructions
Enter Monitor Mode on a PIX 501, 506, 515, 525 or 535
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094a5d.shtml#monitor
Hope that helps!
hemendoz
The OS of the PIX might be corrupted. I suggest reimage the PIX.
I hope it helps .. please arte it if it does !!!
Thanks for your prompt response. It was working well and kept as backup. Nothing changed.
I could not go to the rommon mode. Its stuck after displlaying the msg:
Compiled by morlee
32 MB RAM
PCI Device Table.
Any help pls
Reza
I had the same problem, but atfer several reloads and cutting off power, it started to enter Monitor mode. First it enerts Monitor directly (without giving the option to boot from flash), hence I thought I need to reinstall the OS, so I did that from Monitor mode using the tftp method. The option to boot from flash started to appear and the OS was booted, not from the image downloaded from the tftp server but rather from the one saved originally on the flash; I discovered that after I removed the image on flash to make space for the new image. A strange thing has happened, once I removed the image on flash the PIX reloaded giving me no chance to save the new image, and thus the PIX got into a boot loop and every time I try to install the OS from Monitor mode the image is downloaded but the OS doesn't boot and the loop continues.
My PIX was working fine as a Primary in a failover configuration. It became non-operational after a power failure has occured, so my best guess is that a hardware failure is the reason.
The problem is of high urgency for us, so any help will be highly appreciated.
Thanks in advance
Muhammad Raga'ei
358
