Pix 515 with multiple interfaces seeing each others and Active DIrectory
I’ve configured a CISCO PIX 515 E- unrestricted IOS v. 6.1 with 6 interfaces for a Customer. We have hosts on Windows 2000 and NT platform spread in each subnet. I’ve implemented NAT to grant the higher security interfaces to talk with the lower and vice versa.
nameif ethernet0 outside 0
nameif ethernet1 inside 100
nameif ethernet2 ServerFarm 50
nameif ethernet4 DMZ_Pubblica 30
nameif ethernet5 DMZ2 80
ip address outside 172.16.80.1 255.255.255.0
ip address inside 172.16.16.1 255.255.255.0
ip address ServerFarm 172.16.1.1 255.255.255.0
ip address DMZ_Pubblica 172.16.48.1 255.255.255.0
ip address DMZ2 172.16.64.1 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
nat (ServerFarm) 1 0.0.0.0 0.0.0.0
nat (DMZ_Pubblica) 1 0.0.0.0 0.0.0.0
nat (DMZ2) 1 0.0.0.0 0.0.0.0
global (outside) 1 172.16.80.101-172.16.80.130 netmask 255.255.255.0
global (ServerFarm) 1 172.16.1.101-172.16.1.130 netmask 255.255.255.0
global(DMZ_Pubblica) 1 172.16.48.101-172.16.48.130 netmask 255.255.255.0
global (DMZ2) 1 172.16.64.101-172.16.64.130 netmask 255.255.255.0
static (inside, DMZ_Pubblica) 172.16.48.50 172.16.18.50 netmask 255.255.255.255
So when a host on DMZ_Pubblica needs to access a server, with IP address 172.16.18.50, in inside network, will have to open a session with 172.16.48.50.
The Active Directory is in the subnet named ServerFarm. When the Active Directory Server receives a request coming from a host in DMZ_Pubblica, with IP address 172.16.48.yy, to resolve the name for a server in the network inside, with IP address 172.16.16.xx, the AD Server will have to answer the IP address natted 172.16.48.xx. When the AD Server receives a request from a host in DMZ2, with IP address 172.16.64.zz, for the same server in the network inside will have to give another IP address natted 172.16.64.xx and it’s impossible.
I can fix it with lmhosts files or I must modify each WINS server, but the customer would rather not do that on every machine and complains because he believes it takes too long to resolve names. Is there any other solutions?
May I not apply NAT mechanism between the interfaces?
Thanks in advance
Simon
1 REPLY
VIP Purple
Re: Pix 515 with multiple interfaces seeing each others and Acti
I'd consider not using NAT between the internal interfaces.
However, there is another solution. Read up on the "alias" command. This tells the PIX to re-write the IP address returned in DNS queries on the fly.
85
