PIX 515E Failover booting issue
sajan1234
PIX 515E Failover continious booting with out normal prompt. I removed the failover connectivity,reboot it again,remove the cards and even firewall continious booting
5 Replies 5
timkaye
Hello.
Your firewall is licensed for Fail-over only.
This firewall needs to be connected to another firewall in order to run.
This is its default behavior.
Tim
Dear Tim,
It was connected with Active Firewall & working fine, now it has given this internal error.Please find my attached booting sequence.
An internal error occurred. Specifically, a programming assertion was
violated. Copy the error message exactly as it appears, and get the
output of the show version command and the contents of the configuration
file. Then call your technical support representative.
assertion "result" failed: file "crypto_nist_tests.c", line 406
Thread Name: initpix/intf1 (Old pc 0x001162e1 ebp 0x00ddb9d0)
Traceback:
0: 004bb6a5
1: 002fb7d6
2: 002e87a8
3: 002e88ac
4: 001036dd
5: 00000000
vector 0x00000003 (breakpoint)
edi 0x002fb6c8
esi 0x00000196
ebp 0x00ddba40
esp 0x00ddba34
ebx 0x002fb6cf
edx 0x000003fd
ecx 0x0000000a
eax 0x00000040
error code n/a
eip 0x004befb4
cs 0x00000008
eflags 0x00000246
CR2 0x00000000
Stack dump: base:0x00dd9b3c size:8192, active:392
0x00ddbb38: 0x00000001
0x00ddbb34: 0x002e8844
0x00ddbb30-0x00ddbb2c: 0x00000000
0x00ddbb28-0x00ddbb0c: 0x12345678
0x00ddbb08: 0x00000001
0x00ddbb04: 0x001036dd
0x00ddbb00: 0x00ddbb2c
0x00ddbafc-0x00ddbaec: 0x12345678
0x00ddbae8: 0x00000000
0x00ddbae4-0x00ddbae0: 0x12345678
Dear All,
Any update on this issue, i am surprised to see this messege when my failover box boots, it is continiously booting with out stopping.
Hi Sajan,
I believe you got VAC+ card connected to PIX515E See removing the vac+ card fix the issue .
traceback indicate the vac+ card was the issue for crashinfo ..
There is a junk bug filed in 6.3.1 ..not sure you have access to that bug tool or not
CSCec50850
Here is link for bug tool kit
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
If removing the VAC+ card resolve the issue .. its gr8 else see software upgrade helps..otherwise.. hardware issue
Pls rate it helps your issue to resolve to that other can take benefit of this forum
jojuarez
The bug the other user mentioned is junked, so it is not that bug.
I noticed that you're running a very old version, please do an upgrade at least to 6.3.5 as several defects have been fixed since then.
