PIX 515E, pre-shared key and dynamic maps
franzin
Dear Sir / Madam
We are operating a network with 120 sites. We have a PIX-515E acting as
a hub point and Contivity 100 in the remote offices.
At the branch office we use a dedicate IP line (128 K) and at the hub point
a 8 Mbps dedicate IP line, establishing tunnels through IPSEC using
pre-shared key. All is working well with good performance and low costs.
When we tried to establish a dial backup (Internet) conection from
Contivity 100, it work's fine at the branch office, reestablishing the
Internet traffic and others services, but at the central office the tunnel
can't be establish.
This is due to the static crypto map that needs a peer address to create
a SA. Using a dynamic crypto map this problem was solved and the
tunnel was established with dedicated IP or using dial backup access.
The problem is that I could only use a unique pre-shared key to all
offices and that's a great problem. So I would like to establish
a tunnel using a pre-shared key by hostname instead peer address.
I couldn't find any example or reference of doing this with PIX-515E
software version 6.2
I've seen some configurations using this aproach with IOS 12.2 but
in using PIX I will be in lack of references on how to use a different
pre-shared key and not using the peer address as control / identity.
How can I do it ?
Are there any other way to use different pre-shared keys with dynamic map?
Will it be available at version 6.3?
When do you configure "isakmp identity hostname" for use with IPSEC?
I'm posting a small piece of the configuration:
sysopt connection permit-ipsec
no sysopt route dnat
/*These lines refer to offices with dial backup */
crypto ipsec transform-set AGENCIAS esp-des esp-sha-hmac
crypto dynamic-map backup 20 match address 299
crypto dynamic-map backup 20 set transform-set AGENCIAS
crypto dynamic-map backup 30 match address 300
crypto dynamic-map backup 30 set transform-set AGENCIAS
/* These lines refer to static with no dial backup installed */
crypto map XXX_MAP 301 ipsec-isakmp
crypto map XXX_MAP 301 match address 301
crypto map XXX_MAP 301 set peer XXX.XXX.XXX.XXX
crypto map XXX_MAP 301 set transform-set AGENCIAS
crypto map XXX_MAP 303 ipsec-isakmp
crypto map XXX_MAP 303 match address 303
crypto map XXX_MAP 303 set peer YYY.YYY.YYY.YYY
crypto map XXX_MAP 303 set transform-set AGENCIAS
crypto map XXX_MAP 304 ipsec-isakmp
crypto map XXX_MAP 304 match address 304
crypto map XXX_MAP 304 set peer ZZZ.ZZZ.ZZZ.ZZZ
crypto map XXX_MAP 304 set transform-set AGENCIAS
crypto map XXX_MAP 308 ipsec-isakmp
crypto map XXX_MAP 500 ipsec-isakmp dynamic backup
crypto map XXX_MAP interface outside
isakmp enable outside
/* A diferent pre-shared key for each site */
isakmp key ******** address XXX.XXX.XXX.XXX
isakmp key ******** address YYY.YYY.YYY.YYY
isakmp key ******** address ZZZ.ZZZ.ZZZ.ZZZ
/* One pre-shared key to every site with dial backup */
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash sha
isakmp policy 20 group 1
isakmp policy 20 lifetime 28800
Thanks for any help
Franzin
a-alao
Try using the vpngroup command on the PIX to differentiate between sites.
Configure the Group name and passwords (Preshared Keys) on the PIX.
Check to see if your contivity boxes can authenticate using a username(groupname) and passwords .... Hope this helps
I'm using to mobile users with Cisco Cliente 6.2. It doesn't work with
Contivity!
Unfortunaltely, Contivity can validate a peer using either IP address or
the name of the tunnel (same as hostname for CISCO).
Thanks for your help.
Franzin
