PIX-515E Problem
I have a PIX-515E and today I cannot start it. The message on console is :
CISCO SYSTEMS PIX FIREWALL
Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73
Compiled by morlee
32 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
00 11 00 8086 1229 Ethernet 11
and only this.
Thanks in advanced,
Sorin
Bronze
Re: PIX-515E Problem
If the PIX will not boot completely, there is not much you can do besides replacing the unit.
'return to sender' I am afraid :-)
Kind Regards,
Tom
Hi Sorin,
The flash might be corrupted. Try to upload the new PIX OS through rommon
HATO
Can you help me with the procedure or a link for this ?
If it is the same with router procedure, it wasn’t works.
Sorin
Silver
Hi Sorin,
Could provide you with the link, but I'm pretty sure this will not help you out, cause you would not be able to start this procedure.
Normal PIX boot starts with this:
Compiled by morlee
32 MB RAM
PCI Device Table.
Cisco Secure PIX Firewall BIOS (4.2) #0: Mon Dec 31 08:34:35 PST 2001
Platform PIX-506E
System Flash=E28F640J3 @ 0xfff00000
Use BREAK or ESC to interrupt flash boot.
Use SPACE to begin flash boot immediately.
The procedure of installing another image would at least have the need to get to the point where the PIX says: "Use BREAK or ESC"
This is the point where the PIX will load it's image from flash if you do not press ESC or BREAK. But you are not getting to that point, so, no procedure is available.
What is happening with your PIX is that it does not get to the initial testing sequence of the device (seems it can not load it's own BIOS or that your Flash SIM's are broke.
Only solution here is indeed, like the other guys allready stated, to exchange your box with a new (replacement) one, or at least exchange the SIM's and see if this works.
Kind Regards,
Leo
137
