PIX 515E VPN configuration Problem
I am configuring a PIX 515E Firewall/VPN behind an ADSL Router ( NAT on ADSL not PIX ). Using the attached configuration, Cisco VPN 4.0.3(D) client connect and have IP address assigned but can't access any server on inside subnet, if I ping the remote user from the inside server every thing works fine. Please advise.
Many thanks
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
enable password AAAAA.BBBBBB encrypted
passwd AAAAAAAA.BBBBBB encrypted
hostname PIX-Firewall
domain-name CUSTOMER.local
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
name 192.168.XXX.3 CSG_Server
name 192.168.XXX.2 Metaframe_Srvr
name 192.168.XXX.1 PDC
name 192.168.XXX.254 ISA_Firewall
access-list outside_access_in permit udp any eq 4500 any
access-list outside_access_in permit udp any any eq isakmp
access-list outside_access_in permit tcp any any eq 500
access-list outside_access_in permit tcp any any eq 51
access-list outside_access_in permit udp any any eq 51
access-list outside_access_in permit udp any any eq 50
access-list outside_access_in remark https for CSG Server
access-list outside_access_in permit tcp any host CSG_Server eq https
access-list outside_access_in remark TCP port 80 for CSG Server
access-list outside_access_in permit tcp any host CSG_Server eq www
access-list outside_access_in remark TCP Port 444 for CSG Server
access-list outside_access_in permit tcp any host CSG_Server eq 444
access-list outside_access_in remark TCP-ICA Port 1494
access-list outside_access_in permit tcp any host CSG_Server eq citrix-ica
pager lines 24
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside 192.168.YYY.2 255.255.255.0
ip address inside 192.168.XXX.250 255.255.255.0
no ip address intf2
ip audit info action alarm
ip audit attack action alarm
ip local pool VPN_clients 192.168.XXX.60-192.168.XXX.90
ip local pool VPN_clients_2 192.168.YYY.30-192.168.YYY.200
pdm location ISA_Firewall 255.255.255.255 inside
pdm location CSG_Server 255.255.255.255 inside
pdm location PDC 255.255.255.255 inside
pdm location Metaframe_Srvr 255.255.255.255 inside
pdm location 0.0.0.0 255.255.255.255 outside
pdm location 192.168.XXX.0 255.255.255.0 outside
pdm location 192.168.XXX.0 255.255.255.128 outside
pdm history enable
arp timeout 14400
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
static (inside,outside) CSG_Server CSG_Server netmask 255.255.255.255 0 0
static (inside,outside) Metaframe_Srvr Metaframe_Srvr netmask 255.255.255.255 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.YYY.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http ISA_Firewall 255.255.255.255 inside
http PDC 255.255.255.255 inside
http Metaframe_Srvr 255.255.255.255 inside
http CSG_Server 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
sysopt connection permit-l2tp
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp enable inside
isakmp identity address
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup CUSTOMER address-pool VPN_clients
vpngroup CUSTOMER dns-server PDC ISA_Firewall
vpngroup CUSTOMER idle-time 1800
vpngroup CUSTOMER password ********
telnet PDC 255.255.255.255 inside
telnet Metaframe_Srvr 255.255.255.255 inside
telnet CSG_Server 255.255.255.255 inside
telnet ISA_Firewall 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn enable outside
vpdn enable inside
terminal width 80
Cryptochecksum: aaaaaaaaaaaaaaaaaa
: end
1 REPLY
Re: PIX 515E VPN configuration Problem
If your router is doing NAT, then you need to inform the PIX of this - the function you need is called NAT-T and can be enabled on your pix with the following command:-
isakmp nat-traversal 20
regards,
Rowan
97
