PIX 520 Failover
mowtnman
I have 2 PIX 520's setup with failover between the 2. If you unplug an interface that is in a switch or hub this will cause failover between the two... Failovers kill connections. I need to move the connections into a new switch without causing a failover between the 2 devices. Is there a way to do this? The interfaces I need to move are neither the inside or outside interface of the Pix...
Thanks in advance.
r-simpson
Level 3
Level 3
You would have to enable stateful failover to maintain the connection states during the failover event.
klouthan
You have to dedicate a link to pass the stateful information.
Then you use a crossover cat5 cable to link the two interfaces together.
Then apply something like below :
nameif ethernet4 fail-interface security10
failover link fail-interface
ip address fail-interface 10.254.254.249 255.255.255.252
failover ip address fail-interface 10.254.254.250
