Pix 520 ignoring unknown PCI card
I've just upgraded a 520 chassis with PIX-FLASH-16mb kit, and then upgraded
s'ware to 6.1(4). Then on bootup appears :-
Ignoring PCI card in slot:3 (vendor:0x1329 deviceid:0x1 revisionid:0x0)
Double checked, back s'ware to 5.3(2), message disappears, upgrade
to 6.1(4), message appears again.
remove the pci card, and the message disappears, the box
(seems) to boot normally
The card is marked Productivity Enhancement Products
assy 10573-001 pcb 10573-501
The secondary 520 chassis I have here also has a similar card.
Any ideas what does this card do and why does 6.1(4) not support it ??
Cheers
Martyn
1 REPLY
Re: Pix 520 ignoring unknown PCI card
This is probably the old 2Meg flash card, did you remove it before installing the 16Meg flash card? A lot of people don't, although generally the PIX doesn't even boot up with both cards installed.
Can you send a "sho ver" when running 5.3(2)?
171
