PIX 520 VPN problem w/IPSEC
I am working on a PIX 520 (v 5.2(2)) and when I try to connect via IPSEC, I get the following error:
The remote peer does not support the required VPN client protocol. Contact your system administrator.
Also, when I try to connect using PPTP, I get connected, however, I can't ping anywhere on the internal network.
HELP!!!
Re: PIX 520 VPN problem w/IPSEC
I guess the PIX is not configured to take IPSec client connections thats why you get that error message. Additionally you want to make sure that the PPTP is let through the PIX and that TCP port 1723 and GRE are allowed to the PIX for PPTP to work aswell. Also make sure you are not coming in from behind a PAT device while connecting to the PIX, it doesn't support that at this time.
Hope this helps,
Aamir
I just posted the same problem in the current "Ask the Experts" post, so if this is redundant, ignore the other.
I am able to connect with the same config on 506 box. I have checked the configuration about 10 times to make sure I am not forgetting something. This is the pertinent excerpts:
access-list 101 permit ip 172.16.1.0 255.255.255.0 10.10.10.0 255.255.255.0
ip local pool vpn-ip-pool 10.10.10.1-10.10.10.254
nat (inside) 0 access-list 101
sysopt connection permit-ipsec
sysopt connection permit-pptp
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup peii address-pool vpn-ip-pool
vpngroup peii dns-server 172.16.1.235
vpngroup peii default-domain peii.com
vpngroup peii idle-time 1800
vpngroup peii password xxxx
vpdn group 1 accept dialin pptp
vpdn group 1 ppp authentication pap
vpdn group 1 ppp authentication chap
vpdn group 1 ppp authentication mschap
vpdn group 1 ppp encryption mppe 40
vpdn group 1 client configuration address local vpn-ip-pool
vpdn group 1 client configuration dns 172.16.1.235 172.16.1.245
vpdn group 1 client authentication local
vpdn username XXX password XXXX
vpdn enable outside
Sorry, one other thing...
Do I have to have 1723 and GRE open even when the PIX handles the PPTP authentication? See previous msg for config...
Thanks a bunch...
-st
91
