PIX 525 - Stops forwarding traffic outside to Inside
I have a PIX 525 running 6.1.1 OS
I have an ACL from outside to inside. Atfter an undefined time the pix stops forwarding traffic from outside to inside. The only way I have found to fix the problem is to remove and then re-apply the ACL and it willl work again (for another undefined period of time).
Does anyone know why? or what i need to do to fix this ?
1 REPLY
Re: PIX 525 - Stops forwarding traffic outside to Inside
I have no experience with this kind of problem. But maybe you could try to upgrade the PIX OS to version 6.2?
Kind Regards,
Tom
92
