Pix 525 Unrestricted with 1 4-port FE + 2 GE
We installed two new PIX-1GE-66 and the link on these two new interfaces does not come up.
We tested the connection with a router and a switch, but the link stays down.
The show interface shows HW UP Protocol Down.
Any idea?
Does anyone know any test that I can use in this case?
thanks in advance
Gold
Re: Pix 525 Unrestricted with 1 4-port FE + 2 GE
Maybe you need bring interface UP try command
interface ethernet0 auto
M.
Bronze
Hi Luciano,
If the interface is up and the protocol is down, you would need to check the other end of the cable (i.e. the switch or router interface, are they administratively up or down)? also, It could be a faulty cable you are using, have you tried another one?
That's all I can think of,
Thanks and regards,
88
