PIX 6.1 upgrade to 6.2(2) Problem
We are using the Cisco VPN Client 3.6 for our remote users to log in to our 515e with the configuration below. It worked fine until I upgraded the PIX from 6.1 to 6.2(2) and even though they can log in and browse the 192.168.10.0 network,they can no longer access the subnets.
The error message in the sys log when I try and ping one of the subnets from a connected client is PIX-3-106011 Deny inbound (no xlate). I can ping the subnets from the inside interface of the PIX.
I'm going through the 6.2(2) configuration book but can't find anything that would have changed between the versions. Any ideas on this?????
: Saved
: Written by enable_15 at 05:07:24.286 UTC Mon Nov 17 2003
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security10
enable password xxxx
passwd xxxxxx
hostname PIX
domain-name TEST.COM
fixup protocol http 80
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol smtp 25 no fixup protocol h323 h225 1720
no fixup protocol sqlnet 1521
no fixup protocol rtsp 554
no fixup protocol sip 5060
no fixup protocol skinny 2000
no fixup protocol ftp 21
names
access-list Cisco permit ip 192.168.10.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list Cisco permit ip 192.168.20.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list Cisco permit ip 192.168.30.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list Cisco permit ip 192.168.40.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list Cisco permit ip 192.168.50.0 255.255.255.0 192.168.10.0 255.255.255.0
pager lines 24
logging on
logging trap informational
logging host inside 192.168.10.35
logging host inside 192.168.10.98
interface ethernet0 10baset
interface ethernet1 10full
interface ethernet2 auto shutdown
icmp deny any echo-reply outside
icmp permit any unreachable outside
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside 12.188.60.212 255.255.255.240
ip address inside 192.168.10.67 255.255.255.0
ip address intf2 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
ip local pool dealer 192.168.10.120-192.168.10.125
pdm history enable
arp timeout 14400
nat (inside) 0 access-list Cisco
static (inside,outside) 12.188.60.213 192.168.10.101 netmask 255.255.255.255 0 0
access-group ACL_IN in interface outside
route outside 0.0.0.0 0.0.0.0 12.188.60.211 1
route inside 0.0.0.0 0.0.0.0 192.168.10.1 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set aaades esp-3des esp-md5-hmac
crypto dynamic-map dynomap 10 set transform-set aaades
crypto map vpn 20 ipsec-isakmp dynamic dynomap
crypto map vpn client authentication
crypto map vpn interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpnone address-pool dealer
vpngroup vpnone dns-server 192.168.10.95
vpngroup vpnone wins-server 192.168.10.95
vpngroup vpnone default-domain test.com
vpngroup vpnone idle-time 1800
vpngroup vpnone password *****************************
telnet timeout 60
terminal width 80
Cryptochecksum:xxxxxx
: end
Re: PIX 6.1 upgrade to 6.2(2) Problem
Woah, get rid of the two default routes, that hasn't been supported for quite a while. I'm surprised it even worked with 6.1. Do this:
no route inside 0.0.0.0 0.0.0.0 192.168.10.1
route inside 192.168.0.0 255.255.0.0 192.168.10.1
and see how that goes.
That fixed it. Thank you so much gfullage.
89
