PIX 6.2 and PDM 2.0 - Great Combination !!!!
I would like to mention that above mentioned combination is EXCELENT!!! Try it out... Remote access VPN is now just few clicks away...
Sasa
Re: PIX 6.2 and PDM 2.0 - Great Combination !!!!
They have a new version of PDM out...excellent! Do you have the link to download it?
I have a question. I currently have PIX 6.1(1) up and running. Can I install the PDM while users are running? Will there be an interruption of service?
I just did it so I can tell you first hand:
If you upgrade the PDM to 2.0 it will not interrupt service.
However, to run PDM V2.0 you need to upgrade your PIX image to 6.2. Just copy the new image into flash. Then when you can afford downtime reboot the PIX. The new image will be loaded and you can run PDM V2.0
101
