PIX 6.2 to 7.1 conversion
Hi all, well I'm new to the PIX world so if anyone can help, here goes.
Is there a tool that converts PIX 6.x ios configs to 7.1. I'm going from a PIX 506 to a 525.
1 ACCEPTED SOLUTION
Gold
Re: PIX 6.2 to 7.1 conversion
if you're using conduits, you can convert them to ACL's using the OCC tool available here:
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
other than that, there's no tool for what you need. most of the commmands will be the same though. It will be easier if you first upgrade the 506 to 6.3(5) though.
1 REPLY
Gold
87
