Highlighted
Community Member
Pix 6.3 with 2 interfaces and 2 ISP
I have a pix with 2 ISP on 2 outsides interface I know that I can only have one default route,
but with a different metric I can use it as a backup link or with a specific route I can use it.
My problem is that the backup link use a private address who overlap with my internal network and my question is
Is it possible to translate my inside source ip addresses and to balance traffic to both ISP with static route default or not ?
1 REPLY
Silver
Re: Pix 6.3 with 2 interfaces and 2 ISP
To the best of my knowledge, You can route the packet only using a single gateway as per in static routing. If you are using the dynamic routing, probably have using the metric you can play to load balance.
105
