PIX 7.0: administering using remote Access VPN.
I can't admin the PIX using a Remote access VPN, I tried ASDM and telnet, but I can't make it work.
Please, some one can post a example config?. On CCO I only find how to admin using a L2L VPN.
Thank you very much
J.
Gold
Re: PIX 7.0: administering using remote Access VPN.
apply the following commands on pix v7:
management-access inside
telnet inside
http inside
There does seem to be a bug after a reload of an ASA running 8.2(1).  Prior to reload (yes I saved my configuration) I was able to telnet to the inside interface of the ASA through the remote access VPN client.  After reload, I could ping the inside interface and could telnet to it, but would get a blank screen and then I would get disconnected as soon as I pressed a key.  I removed the "management-access inside" command and re-added it which fixed my problem.  I wonder if I will have to do this next time I reload.  I need to upgrade to 8.2(3) anyway.
352
